injector upgrade
Old Mar 19, 2006 | 01:15 PM
daves12secV6's Avatar
injector upgrade
since im gonna run the turbo,and i want to run over 7psi,are thesse injectors bigger then the 2.8 injectors
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Mar 19, 2006 | 02:54 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
theyre 17# instead of #15, but you can get #17 injectors from a 3.4, or better yet #19 SVO injectors, you can find sets of those for cheap all over ebay(and at GM fuel pressures they flow more like 21/22 lbs). What kind of HP are you making, and are you planning on tuning the ECM to adjust for the injectors(or just a fmu)?
Old Mar 19, 2006 | 03:06 PM
well im gonna go with fmu for now, which if what ive been told is right,i wont need the fmu till i pass the 7psi mark,
with that said i was also told the stock injectors would be fine with an fmu upto about 10 psi but lock up above 72psi fp
so i was thinking slightly larger injector with slightly less fp
Old Mar 19, 2006 | 04:14 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I got some ones rob suggested. 18.55 lbs out of a buick. They were hard to find, but the easy ones to find are 18.1 IIRC.
Very quiet too!!
Old Mar 19, 2006 | 04:18 PM
Naft's Avatar
hmm wait, i just noticed some inconsistencies in my post lol . . . 3.4 injectors are #17, i dont know for sure what size 3.1's are, i know they arent 17 though. i think maybe 15 and 2.8s are like 14 or something . . .
i dont know that much about fmu'ing these injectors, my plan is either tuning the ecm for the injectors or maybe running a stealth megasquirt setup but keeping the old ecu for easy emissions testing (if i build the MS stuff myself it ends up costing about the same as tuning equipment for the stock ecm, but its a crapload better and is still easier/cheaper than switching to 730 or 749 . . . especially if i want to keep everything else stock). FMU's seem to be a little guessworky anyways, so i would step up an injector size or two anyway just to be on the safe(rich) side.
Old Mar 19, 2006 | 04:52 PM
dale willing to sell them?
Old Mar 19, 2006 | 07:36 PM
Dale's Avatar
Engine: 350 S-TPI
No, I'm running them But they came in buick um, ****....The FWD 3.8. They look totally different then ours. I posted a picture of them in my recent thread.
If you need the part number, let me know as I can easly view it right now.
J-money
Jan 4, 2019 09:45 AM
BAMiller
Sep 14, 2015 06:38 PM
toyotekk
Sep 7, 2015 06:36 PM
Billy Decker
Sep 4, 2015 03:46 PM
rudolphschenker
Sep 4, 2015 02:41 AM
