anyone whos installed new springs, reply as fast as you can
Old Mar 22, 2006 | 08:25 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
im on a bit of a time crunch and trying to get my heads together and found that my new springs have the extra coil. theres an insert on the original springs that comresses, but enough to fit in the new ones. has anyone else had this problem? should i just disregard them or is there a way to install them?
Attached Thumbnails anyone whos installed new springs, reply as fast as you can-intake.jpg
Old Mar 22, 2006 | 08:33 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
mine were installed by a shop, sorry bro.
Old Mar 22, 2006 | 08:35 PM
drdave88's Avatar
Engine: 6.0L
dale......... youre not helping me
lol
Old Mar 22, 2006 | 09:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, after looking a the pic and a look-see in the Helm manual: the piece in the right side of your pic I would discard. It is an oil splash shield. Note that by discarding it the spring installed height will be increased. Should also be using a good valve stem seal(s).
The new springs are single wound with a damper. The stock springs are single wound w/o a damper. Guess GM needed to fit the splash shield.
When I build up hi-po street heads I discard the upper splash shield. Use an O-ring seal on the retainer. And use a positive seal on the intake stem, and an umbrella seal on the exhaust stem. These seals are fit to the top of the guide.
RBob.
Fast355
Dec 2, 2016 06:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
