Gas in the oil from leaky injectors ?
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
Anyone ever had this problem ? I thought it was the fuel pump, but I found out I have an electrical one and not a mechanical one. Only other thing I can think of is the rings.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Any time you either have a rich condition for an extended period or something like a leaky injector, you get gas in the oil. No ring is a 100% seal on the cylinder wall, so you always get something in the oil. That's why the oil turns black after 3000 miles.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'm gonna try to get a compression test done tonight at the shop.
Whatever it is is getting a lot of gas in the oil. I changed the oil a couple of weeks ago with 20w50 and it's already thinned out a lot.... The color of the oil is also different than normal, it's not like a Wendy's frosty lol but you know how normal old oil is kinda dark brown and blackish? Mine is kinda grey looking.
Originally Posted by Toehead
Water in the oil will give it a grey, milky color.
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
