Where is the heater control valve on a 2.8? Does it have one?
Old Mar 30, 2006 | 02:34 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I junked the 2.8 from my Firebird and installed a 305 roller motor in its place. I have completed converting most of the wiring, computer, and emissions routing to the 1983/84 V8 configuration. However there is one thing I noticed. The V8 uses a heater control valve that is under the hood, inline with one of the heater lines coming off the firewall. It has a small vac line to switch coolant supply to the heater core on/off. I can not locate a heater selector/control valve under the hood on the V6. Does it have this part at all (I know a lot of old cars didn't have a heater control valve, hot coolant always flowed through the heater core, and then the blower motor simply controlled whether or not you had heat). If it does have a heater control valve, is it under the hood like a V8 or inside the car? It was a 2.8 AC car if that matters. I kept AC with the V8.
Old Mar 30, 2006 | 08:03 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
That little piece o' happy is located between the #1 and #3 (PASSANGER side).
It's a black plastic valve, with 2 lines on one side, and 1 on the other, with a UFO on top.
I'd recommend ditching it, myself.
Old Mar 30, 2006 | 11:48 AM
Car: 2000 BMW M5
Doward the car is no longer a V6. Where is "between #1 and #3", was it up on top of the engine and clearly visible? I know what a heater control valve looks like w/ the UFO thing on top, I just can't find it on this car. The 2 lines for the heater come out of the firewall and go straight down. Eventually they end up as 2 metal hard lines on the pass side frame rail, and then become rubber hoses again. The previous owner had removed some of the emissions equipment on the 2.8. I can see him thinking the heater control valve was a piece of smog equipment and removing it. I will go junkyard searching for another heater control valve. Where does the tiny vac line on top of the UFO thing come from? I know that is the switched vac to turn the heat on.
Old Mar 30, 2006 | 02:15 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
my car didn't have one, or the first owner took removed it before it got to the dude I bought it from. Check & see if your 83 came w/one origonally i.e. call parts store & see if they list one).
Old Mar 30, 2006 | 04:25 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
The vacuum line for the control valve goes into the harness on the HVAC box on the firewall. I assume it goes inside the car from there. The harness and vacuum line are all wrapped up in black tape on my car.
Old Mar 30, 2006 | 10:25 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
thats where it is on my 86 2.8L and my 88 5.7TPI.
Old Mar 31, 2006 | 01:11 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
hmm my 83 doesnt have that vacume line.. nor any holes for that.. although my 2.8 is carbed if that makes a difference.
Old Mar 31, 2006 | 01:35 AM
Car: 2000 BMW M5
This 83 2.8 Carbed car does not have that vacuum line either. It has the black vac. reservoir thing behind the brake booster with a line going into it coming across the engine bay, thru the firewall from the heater box area. The other port on the vac. reservoir is disconnected and I am trying to figure out where it goes. Gah! This is so frustrating
Old Mar 31, 2006 | 01:46 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
heres my engine bay.. just for a comparason to the other year car
Attached Thumbnails Where is the heater control valve on a 2.8? Does it have one?-car15.jpg   Where is the heater control valve on a 2.8? Does it have one?-mycar-015.jpg
Old Mar 31, 2006 | 02:25 AM
Car: 2000 BMW M5
Here's the answer -- I consulted my 1983 factory service manual. NO ENGINE in 1983 in the F car had a coolant valve. Heat was controlled simply by the heater door. The inline 4, V6, and V8s in 1983 were all plumbed like an old car -- the heater core always has coolant flowing through it no matter what. I should have consulted the FSM in the 1st place. This makes my life a lot easier.
Old Mar 31, 2006 | 11:05 AM
Engine: 5.7 / 7.4
I wonder if 86 was the first yr for that valve
1992 Trans Am
May 10, 2023 07:19 PM
NORTz89
May 20, 2020 03:51 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
