2.8 carbed choke wire -- what color (pic if possible)
Old Apr 5, 2006 | 12:18 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am almost done wiring my 1983 V6 to high output 305 V8 swap (also carbureted). The previous owner cut some wires when he converted the 2.8 to a manual non computer controlled carb a while ago, so I am unsure of whether I have found the correct wire for the choke or not. All of the wiring diagrams for the 1983 V6 I have show it should be a light blue wire. Obviously it has that weird single connector on the end that fits the L shaped tab on the carb's choke heater. I found one wire that connects to the choke with the proper connector but it is not solid light blue, it has a color and a tracer (I don't recall what colors they were). If anyone can confirm what color their 2.8 V6 choke wire is, and/or take a picture of it, that would be fantastic. Thanks!
Old Apr 6, 2006 | 03:37 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
All you need is a wire that gives out 12v when the ignition is on. I've become accustomed to getting out my multimeter and testing the voltage when I lose track of wires like that. I've lost all faith in wire diagrams over the past few years... probably goes hand in hand buying used cars.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Linson
Aug 21, 2015 02:12 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
