Valve guide seals??
Old Apr 7, 2006 | 07:52 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Valve guide seals??
Well I checked the compression on all my cylinders and they were all around 160-180.. I pulled the pugs again and one still had oil deposits.. Only other reason that I could think of would be the valve guide seals... how hard are they to replace? Thanks
Old Apr 7, 2006 | 01:39 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
They're not "hard," but there is a lot of work involved. You have to pull the valve covers, remove the rockers, either use string or compressed air and an adapter to keep the valves closed and from falling into the engine. then you have to compress the spring, pull the retainers out and then you can get to the guide seals. Installation reverse of removal.
Sounds almost like a Haynes manual, huh? lol
Old Apr 7, 2006 | 02:01 PM
Should I bother replacing them or should I just wait till my engine swap? It shouldnt be more than a week before its ready.
Old Apr 7, 2006 | 02:02 PM
daves12secV6's Avatar
**** if ur swaping the motor in a week why bother,just stick a hotter plug in the cyl with the leaky seal for now
Old Apr 7, 2006 | 02:06 PM
Well Im gonna try n find a 5-speed car first instead of the auto...
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
hdis2002
Sep 8, 2015 02:52 PM
tgp1990
Sep 4, 2015 06:24 AM
