v6 stroker???
Transmission: 5-speed/T-5
Originally Posted by jdk1987
Are the 3.4 and 3.8 cranks different from the 3.1? Is a v6 stroker possible? Just curious...
The 3.4 crank is the same as the 3.1.
The 3.8 is a completly different species.
Essentially the 3.1 is a "stroker" 2.8L.
You could offset grind a crank to create a longer stroke, but the 3.1/3.4 crank is already too long for a good rod ratio as is, well not too long, but I don't think I'd want any longer because then the ratio will be too low.
Chevykid810
Sep 28, 2015 12:57 PM
