I've got crickets in my engine and it's not the belt
Old Apr 17, 2006 | 11:03 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I've got a squeaking noise coming from the engine. It only happens when the engine is warm. The belt was replaced a year ago and shows no signs of slipping. The tensioner is a month old. The noise seems to be coming from the passenger side, which would be alternator, tensioner, or smog pump. I listened to all of the accessories with a screwdriver, and they all sound normal. Any ideas? Thanks
Old Apr 18, 2006 | 08:13 AM
camarolizard's Avatar
Car: 84 sport coupe
Engine: 2.8,for now
Axle/Gears: junk
remove the serpertine belt,start the engine,and see if the noise disappears.if it does,it is in the accessory drive or the belt
Old Apr 18, 2006 | 06:02 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
While the belt is off spin the pulleys by hand.
Old Apr 18, 2006 | 07:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
speedo cable
Old Apr 18, 2006 | 09:51 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
It's got a VSS, not a cable. I'm pretty sure it's an accessory, but I haven't pulled the belt yet to confirm it. It sure would be easier to have a vee belt set up so I could pull them one at a time, but I guess I've got to work with what I've got. Thanks for these and any future responses.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
scottmoyer
Aug 9, 2015 10:18 PM
