gauge questions
Old Apr 20, 2006 | 09:26 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
gauge questions
How would i go about fixing my oil pressure gauge and temp gauge? I don't know where to begin, is it a fix that can be done behind the cluster? My speedo is not working right either, if the car is cold and accelerate to quickly the speedo goes crazy, the needle moves back and fourth very quickly. I've gotten two ticket in the mean time, but the cops won't except it as an excuse for speeding.
Old Apr 20, 2006 | 10:27 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
hope this helps
oil pressure is probalby the sender, they go bad offen, it is located in the oil filter housing on the drivers side, has 1 yellow wire going to it. for temp guage, try the sensor that is in the front of the intake manifold, there are 2 sensors there, its the one with the bigger clip with the metal lock wire thing, the other sensor has black and yellow wires going to it, as far as the speedo, once again, check loose connections and/or replace the speed sensor in the tail shaft, the drivers side rear of the trans.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
