any expearence with a 88 2.8 gasket set?
Old May 1, 2006 | 11:31 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
I'm ordering a head set right now for my 2.8 3.4 swap i got the exhaust manifold and oil pan gasket. I was told that they don't make complete engine gasket kits and more that i just gotta buy them seperetely. now would i have all my gaskets i neeed from those 3 sets, (ex. man.,oil pan, head set) that i will need to rebuild it.
Old May 2, 2006 | 03:01 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Don't know who told you that story. I got my rebuild set from GM and it included all the gaskets for the 2.8, 3.1, and 3.4 blocks. Just had to use what I needed for my 2.8 and discarded the rest.
Old May 2, 2006 | 11:14 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
oh i ment the fel-pro gaskets, i orderd the head set yesterday they should be comming in tomorrow so i'll get to find out.
Old May 3, 2006 | 10:37 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep, you can get a head gasket set, and then just the oil pan gasket + rear main seal.
I don't believe FelPro has a specific KS (engine kit) series gasket set for the 2.8...
Old May 3, 2006 | 01:37 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
ya i'm getting the head set tonight i already got the exhaust manifold gaket and the oil pan gasket.
but do u think i should replace the rear main seal since i'm there right now and it won't be as bad as a job now than if would be in a future case?
Old May 15, 2006 | 08:32 PM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
Exhaust manifold
is the exhaust manifold the same for the 2.8 through 3.4 Crate engine. I never had a 2.8 or 3.1 I just recently bought the 3.4L Performance crate engine and just wanted to know.
Thx
Paul
Old May 16, 2006 | 08:44 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
if ur doing a swap then get the 2.8 ones if not just get the 3.4 ones just to make sure but i'm like 99.99% sure they would be exactly the same since the exaust manifolds themselfs are the same.
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
