more help needed!!
Old May 3, 2006 | 09:29 AM
metalhead5's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8L V6
Transmission: 700r4 big old automatic
Axle/Gears: 3.42 one wheel smoker
more help needed!!
I was driving my camaro the other day and i was going up a hill, all of a sudden the speedo needle started jumping like crazy and then dropped to zero. The car stopped shifting in to overdrive and then the check engine light turned on. I pulled the codes and got a vehicle speed sensor code. Would my speedo cable breaking (if that is the problem) cause the car to throw the code.
Old May 3, 2006 | 09:53 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
yes it would. IIRC, the speed sensor in cable driven cars is up in the dash. Which would make it throw a code.
Old May 3, 2006 | 11:24 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Exactly true. The VSS is an optical sensor on the back of the speedo, driven by the cable.
I suggest that you get a cable AND housing for it when you replac it because the cable has worn the inside of the housing and might screw up the new cable.
Old May 3, 2006 | 03:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When did the full electric VSS's start for Camaros? 89?
Old May 3, 2006 | 03:53 PM
Dale's Avatar
Engine: 350 S-TPI
my 91 has it, IIRC the 90 has it also.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
