rocker arm set-up 3.4
Old May 9, 2006 | 04:03 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
i'm putting my rocker arms on they have a way diffrent set-up then fords so i'm kinda lost on this one. The gm shop manual for my 88 camaro says to "tighten them till there is no more 'lash' and then another 1 and a half turns." I have no clue what they mean by lash is it until the rocker arm will not move freely then tighten the extra one and a half?
Old May 9, 2006 | 06:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
even fords have lash, of usede too (silly underpowered modular engines )
anyway, lash.. when the pushrods no longer have any up/down movement between teh lifter/follower and the rocker arm. some like to tighten until the pushrod will no longer spin around, and the othe rway is to pressurize the cylinder chamber using air tank/compressor & stop torquing jsut before the valve open & lets all the air out
Old May 9, 2006 | 07:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Lash = up-down play. With a slight bit of drag on the pushrod when spinning it between the fingers.
Since your somewhat new to gm's, I'd say 1-1.25 turns tell you have done it a few times. Also check compression in the cyls before you put everything back together.
Old May 10, 2006 | 02:54 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
cool thanks guys i figured that's what it ment but i wasn't sure. I also ment the fords are one a bolt type deal and these are on a stud.
Old May 10, 2006 | 03:02 PM
Dale's Avatar
Engine: 350 S-TPI
Thats gen 3 style.
Old May 10, 2006 | 03:04 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
oh cool ****
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
New2Chevy
Sep 28, 2015 12:35 AM
