not idling well
Old May 9, 2006 | 05:21 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
not idling well
my car won't idle at a constant rpm. It keeps jumping from 1000 to about 2200 rpm. Anybody have any diagnoses??
Old May 10, 2006 | 02:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sure, you need to clean the IAC (idle air control) motor's pintle (pointy tip) and passageway.
Tech info here:
https://www.thirdgen.org/forums/v6/1...ac-system.html
Old May 10, 2006 | 08:08 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Have you driven the car since you installed the new IAC?
You have to go above 40mph for the IAC to reset to 0 and the computer to be able to idle correctly. Then check for Vacuum leaks around the hoses, brake booster and intake.
Unmetered air leaks are the #1 cause of erratic idle.
Old May 10, 2006 | 09:20 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
No I haven't driven it yet this year cause I didn't want to mess anything up more. I guess you know what I'll be doing tomorrow.
Old May 11, 2006 | 08:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh you got a new IAC? Yeah, the computer's gotta put it into correct position...
Old May 11, 2006 | 11:31 AM
mvftw's Avatar
EGR hanging open will cause it...
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
