Speedometer Cable Problems
Old May 29, 2006 | 07:35 PM
Azul's Avatar
Car: '89 RS/'78
Engine: 305/305
Transmission: 700r4/?
I've been having problems with my speedometer cable, I got on from AutoZone about a month ago and it blew out last weekend, I then got another, and that one blew out two this past Tuesday. I was wondering should I just go get a GM one or is there somewhere else I can look. The one from GM is about $50 and will take about a week to get here. Any suggestions???
Old May 29, 2006 | 11:58 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Is it coming with a new housing, or are you just getting the cable. If you're not getting a housing, get one. It should ALWAYS be replaced whenever you replace the cable itself.
Old May 30, 2006 | 07:16 AM
Azul's Avatar
Car: '89 RS/'78
Engine: 305/305
If you mean the things to screw each end to where it goes yeah, it's not the other universal one that they sell, this other guy mentioned that it's cuz the cable inside is too weak for the car and that's why it breaks, and the one from GM is of better quality.
Old May 30, 2006 | 12:22 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Then there's something wrong with the speedo itself, there's no such thing as a cable that's not "strong enough" for a car.
There should be VERY little resistance anywhere in the cabel/housing/speedo that will cause it to catch and break. If you've replaced the housing and the cable all as a unit, then there's something wrong with the speedo itself.
I think that you should get the GM one anyway since it'll be precut to the proper length and have the ends already on it, you won't have to worry about cutting it and installing the square drive.
Old May 30, 2006 | 05:20 PM
Azul's Avatar
Car: '89 RS/'78
Engine: 305/305
thanks for the info...just fixed it though, it turns out that it was where it goes connected to the transmission the little wheel/gear thing was cracked causing the other wheel/grea to slip and read wrong.
Old May 30, 2006 | 10:40 PM
Azul's Avatar
Car: '89 RS/'78
Engine: 305/305
yeah so it worked for about an hour and then stopped so now im wondering if i just need to get a new speedo cuz i've already changed pretty much everything else...any info please
Old May 31, 2006 | 09:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What kind of lube are you using on the new cable?
Frozer!!!
Jan 19, 2024 04:55 PM
toones
Jan 6, 2016 06:00 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
AUZ28
Oct 12, 2015 08:40 AM
