Car dead--code 33
Old Jun 1, 2006 | 07:06 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Car dead--code 33
So I was driving home from work and my rpms died than kicked back on 1-2 seconds later, and like 20 seconds later it just died. Luckily I was on a downward hill so I could pull off. To make a long story short I got towed home and I am getting a code 33. I know that it is for my MAP sensor. I was just wondering if there is anything else I should check/change that would cause this code. Any advice/help would be great. Thanks in advance.
Old Jun 2, 2006 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, check if there is spark at one of the spark plugs. Sounds like the ignition module, coil, or pickup coil died. Most likely the code 33 was caused by the engine stalling. Can't hurt to check the vacuum line to the MAP sensor along with the wires to it.
RBob.
Old Jun 2, 2006 | 09:11 PM
grimmcs's Avatar
Car: 91 Camaro
When I was on the side of the road, I had thought it might be a problem with the plugs or wires. Checked the spark plugs and there is no spark. So step one new coil, wires, and plugs. Hopefully that fixes it and there wont be a step two. Thanks again
Old Jun 2, 2006 | 10:22 PM
daves12secV6's Avatar
dont replace all that,its rare for a coil to die,rep[lace the ign module first
Old Jun 4, 2006 | 02:03 PM
grimmcs's Avatar
Car: 91 Camaro
Well I already have all those parts. Ive just been waiting till I got some time to do it. I am going to check the ignition module and probubly change it, just forgot to put that in my last post.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
