Car is runnin HOT!!!
Old Jun 4, 2006 | 11:01 AM
1990GTAboy's Avatar
Car: 1990 Gta Trans Am V6 Turbo
Engine: V6 Turbo
Axle/Gears: I dont know I think they R stock
hey i was driving the other day and noticed that my car was gettin hot. i alwayz check the water and all that good stuff in my car b4 i leave. I met up with one of my friends @ autozone and there was watter all over the ground. i poped the hood and the top hose coming from my radiator was leaking so i fixed it and it is still gettin warm what do you think it might be? could i buy a RamAir kit for it? would that help it keep its cool? PM me W/ info.
Old Jun 4, 2006 | 01:57 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
IF it was leaking theres a good chance you got air in the system. let the car cool off and then take off the rad cap fill till full then run the car for 20 or so minutes and add water as it uses it. after you dont add any water for a good bit of time put the cap back on and fill the over flow tank to the proper level.
Old Jun 4, 2006 | 05:30 PM
1990GTAboy's Avatar
Engine: V6 Turbo
Ok i will do that i did not think of that. i remember it was super low on water that night when i got home i filled it up and filled the over flow tank up to. there might be air in it thanks alot . now about the ram air can i put one on my car?
Old Jun 4, 2006 | 05:36 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Sounds like the Thermostat, also the ram air just allows more air into the intake. u can add it but i dont think itll cool the car down or anything.
Old Jun 4, 2006 | 09:44 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Tricky to fill our cars up. I fill the radiator, start the car and watch the water level, with a gallon of 50/50 at the ready. When the stat opens the water level will quickly drop. Pour in the coolant as soon as it drops. My car will take almost the whole gallon at this point. You can then continue to fill it up by adding to the coolant resevoir to the "full hot" line. Every other day check the reservoir and top it off to the full hot line. Eventually it'll stop dropping and should settle at the full cold line (when cold).
Old Jun 6, 2006 | 10:25 PM
1990GTAboy's Avatar
Engine: V6 Turbo
cool i will try that. the guy that i bought it from said it says it is runnin hot but it is only like 220 i have had it close to the hott line and it runs fine and the check engine light still dont come on. so
Old Jun 6, 2006 | 11:39 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
200-220 is about normal for these engines from what ive been reading.. You really need to worry when it reaches 250 or more... I know before i changed out my thermostat to 180, my car, warmed up was right around 210-220
Old Jun 6, 2006 | 11:42 PM
bfox88's Avatar
Car: 90 IROC-Z
make sure your air dam underneath the car is intact
Old Jun 12, 2006 | 04:46 PM
1990GTAboy's Avatar
Engine: V6 Turbo
cool that is what i thought i got it to where it will run about 220 for a lil bit then it gets hotter and after a wile it cools down
Old Jun 12, 2006 | 11:49 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Sounds like a bad T-Stat to me. If you overheat them, sometimes the spring warps and doesn't allow the plate to open at the proper temp anymore, and most of the time they stick shut. Since you know it overheated, change it on general principle. It's not worth chasing down a temperature problem for a $15 fix.
Also, get the system pressure tested and have the cap tested too. It's a good idea to have it pressure checked at least once a year.
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
