What is this thing? vaccume thing attached to alternator bracket
Old Jun 10, 2006 | 06:22 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
this photo was taken from the passanger side of the car. this device is attached via two screws to may alternator bracket. it is in my way everytime i do anything with my belts and i want it gone. what does it do?
thanks
Attached Thumbnails What is this thing? vaccume thing attached to alternator bracket-dsc_00002.jpg
Old Jun 10, 2006 | 08:34 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
its part "deceleration valve" and part of you pcv vent, you can remove it and plug of the line on the plastic intake tube and at the line going into the TB, and you need to put a vent in place of it on the valve cover, do not plug it off, i had a problem blowing oil out of the dipstick tube after i did this, a valve cover vent would fix this.
Old Jun 10, 2006 | 08:41 PM
Xophertony's Avatar
Axle/Gears: n/a
so if i remove it i will no longer have proper PCV valve oporation? if that is the case i am leaving it alone.
Old Jun 11, 2006 | 12:37 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
it's actually designed to keep the engine from running super rich when you go into decel and are pulling a huge vacuum on the system. The instant that you close the throttle, there's still a few injector pulses that are going on and if that valve weren't there, you'd get black smoke out the tailpipe on most cars. It's there to help with that left over fuel. I wouldn't worry about removing it, it's not hurting anything. Also, that bracket helps to support the Alternator and keep it from moving around, keeping the belt tighter and putting less strain on the tensioner.
Old Jun 12, 2006 | 01:52 AM
Xophertony's Avatar
Axle/Gears: n/a
2point8boy, thakyou for the info on what it does and why. verry interesting.
BTW i am aware of what the alternator bracket is for
i ment the bracket that is screwed on to the alternator bracket that holds the "decel valve" (i named it) in place. it blocks my access to the rear bolt. it is a general pain in my ***. perhaps i will relocate it to the firewall.
any issues with lengthening the vaccume lines going to it you think?
Old Jun 12, 2006 | 08:52 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Oh, I just looked at your picture again and it's a different setup than mine. On my car it mounts between the tensioner and the alternator and helps to keep the alt from rotating toward the driver's side of the car. Your's is behind the alt.
I don't see a problem with relocating it and lengthening the lines. Should be alright.
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jahblah
Aug 12, 2015 05:54 PM
