Tune Up Time + Smog Test
Old Jun 16, 2006 | 08:58 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I just bought a V6 with aluminum heads, and I need to give it a tune up before I go in for my smog test.
I'm just curious what the best choice for plugs would be for the 3.1 with alum heads?
I'll be putting in all the usual tune up stuff as well... O2 sensor, plug wires, filter, etc.
Thanks in advance for the help
Old Jun 16, 2006 | 10:00 AM
mvftw's Avatar
Not sure on the plug type. But run Super 93 gas for the test...
Old Jun 16, 2006 | 11:03 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Plugs, the delco version of whatever it calls for.
What year/model car is this?
Old Jun 16, 2006 | 02:46 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
hey, where did u get the aluminum head?
im looking to do a valve job, but also was
thinking for a whole head swap.
I know there was a online store where they sell
pistons etc for 2.8 3.1s but i lost the link.. let me know thankyou!
Old Jun 16, 2006 | 03:46 PM
Car: '85 IROC
Engine: LB9
I have a 3.1 FWD. Right now it's in a 90 corsica, but I'm leaning heavily toward rebuilding it for my 85 iroc.
Turbo... Of Course
I like how much airspace there is around the 60deg v6.
Old Jun 16, 2006 | 05:07 PM
sogabe's Avatar
Engine: 3.1L
aw, its for FWD then..
i dont think there's alum head for RWD 3.1 is there..?
in the future i was hoping for upgrading pistons, crankshaft and heads etc.. but cant seem to find direct replacement.
Old Jun 17, 2006 | 09:01 AM
Dale's Avatar
Engine: 350 S-TPI
90 corsica is the gen2 design, I would install the gen3 design if you do that.
Old Jun 17, 2006 | 10:29 PM
Car: '85 IROC
Engine: LB9
Is gen3 design the DOHC 4 valve/cyl?
The more I read, the more the Buick V6 makes sense, if a guy were to be doing a complete rebuild.
Old Jun 18, 2006 | 08:34 AM
Dale's Avatar
Engine: 350 S-TPI
gen3 is say 2000+ 3.4 thats in the grandprix, grand am, monte, etc.
Old Jun 18, 2006 | 01:39 PM
Car: '85 IROC
Engine: LB9
I read a piece called the history of the 60deg v6 on the ATI site, and they go from the gen2 to the DOHC v6. But for some reason I get the impression that the gen3 is a pushrod 60deg, and it wasn't mentioned in that write up.
Could you clarify that for me please?
Also, are the FWD tranny mounts different than the RWD?
And if they are would that mean that the FWD 3.1 could not be mated to the thirdgen 700R4?
Old Jun 18, 2006 | 04:18 PM
Dale's Avatar
Engine: 350 S-TPI
yes the gen3 is pushrod. The valves in the heads are larger, plus roller fulcrum rockers... and I think I heard a roller cam too or something.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
ezobens
Aug 19, 2015 10:29 PM
