FWD head for RWD?
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
FWD head for RWD?
ive read stuff like FWD head from corscia to a camaro,
will they fit my 3.1 RWD?
im in need of valve job in near future,
and i just want to swap it instead of rebuilding it,
aluminum head sounds really good.
thanks!
thanks!
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i believe this has been covered before, alot. i seem to remmber you need to swap out pistons too, but i can't remmebr if it was becasue you would get too much compression, or not enough... anyway i would do a search, i am sure somthing will come up.
EDIT i searched for "FWD aluminum heads" and this was the 2nd thread on the list...
SEARCH NEXT TIME!
SEARCH NEXT TIME!
Engine: 3.1L
dizzy? and dis?
sorry ima nub there.. dis as in distributor?
thanks for the info though,
i guess if i want the head, ill need pistons too then eh..
now thats too much money and work now but thanks
Engine: 3.1L
so would that be.. i'll need like MSD ignition box
and ignition coils as well? oh boy..
Transmission: 5-speed/T-5
Originally Posted by Dale
The whole wiring/ecm system out of a doaner car.
The most difficult part is getting a trigger signal for the DIS. If a 2.8 or 3.1 block is used, a custom trigger wheel will need to be used, like I made for my truck.
Engine: 3.1L
actually it isnt as easy as i thought at all..
since i dont have much experience yet,
i'll just stick with stock replacement then..
any1 know of a 3.1 store where they sell like
upgrade pistons and valves for 2.8 or 3.1?
ive seen it somewhere but i forgot and can't find it anymore..
I know there's a webpage of them,
I wanna look at them if any1 know which one im talking about, and hopefully the stuff they sell are compatible with other components..
ARI Racing Engines offers a 2.8 ->3.1 kit. Read about it here...
A.R.I. Engines GM 60-degree V6 - 2.8-3.4 Stroker 816-765-4881
I bought a crank kit from them for my engine.
You can use a JY crank and get some stock replacment pistins s well, probably cheaper to.
Engine: 3.1L
thanks Gymbie, thats exactly the site I seen before.
looks like most of the cool stuff they sell are for 2.8 though..
for god's sake why did i get a 3.1..
JY as in junkyard?
if so when I replace something, I like it new.
i know its money-costing but I want my car to look as nice as newer cars, rust-free.
JY as in junkyard?
Well the 2,8 and 3.1 are the same except for the crank and pistons.....
I dunno about you, but once the engine is all together I can't see any part of the crank, so what it looks like is not a concern, besides, with the oil coating that is on the cranks they usually are rust free anyway.
If it's a wear problem, I wouldn't worry about that, since well I have a 3.1 crank of unknown milage in my turbo hybrid and have had zero problems with it, these cranks are just fine new or used.
I too prefer new for most parts, but I also realize that some parts don't need to be new.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
