Got my Camaro Running!!! Got questions though
Old Jun 25, 2006 | 07:24 PM
grantscamaro's Avatar
Car: 1989 Chevrolet Camaro RS
Engine: 2.8 V6
Hello,
I got my Camaro running last Sunday (a week ago) and finally I have stop driving it after putting 1200 miles on it in one week. But I did do a lot of traveling. I love that car.
I heard I could get this "electronic box" for the r700 transmission that will allow me to flip a switch that you install and the transmission won't shift till an rpm you set it too. I know you can get a stall 4000 torque converter but that is not what I am talking about.
And on one finally note. Does anyone know how difficult it would be to make my 89 Camaro Manual if I got a T5 5 speed manual transmission.
I know that is alot of reading and asking but I really appreciate it.
Grantscamaro
Old Jun 25, 2006 | 10:24 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
well to do a manual conversion from auto
there are sertain things to consider,.,.you would need a manual console unless you fabricated the old one wich is posible., not a majiro prob
also youll need to install a clutch and componets like fluied resivior and clutch cable,.,.,.,.,.i have heard of it being done but never seen it step by step,.,.i believe a searsh can be done in other catagorys other then the v6 board.,,.
As far as a box telling yer trans when to shift not sure if its a good idea for the 700r4 the box i think your refering to is just a chip for the ecu,.it does not realy help "so i hear" From my expirienc the only right way to change the shift points in yer trans is to install a shift kit.,stratigicaly placed berrings and channels inside the trans bodyalow the trans to shift sooner,.i feel it helps the trans last longer as well
as much as you drive its a good thing its not on horse back,.or the sum bi@#@ would be dead right bout now lol...... you ever think about taking up truck driving. hell nowa days youd be on the road less .,,.lol
Old Jun 25, 2006 | 11:13 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
I think the switch your talking about is the torque converter lock up , Look under Tech Articles on the main page https://www.thirdgen.org/torqueswitch
Old Jun 25, 2006 | 11:52 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
I think I may have read wrong... or did you want to change an auto tranny to a standard??
If so, here is the article:
Camarosource.ca - Camaro Message Board :: View topic - **Changing an Automatic into a Standard**
If not, you confused me
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
