Haynes or Chiltons ? Torque specs not the same
Old Jun 25, 2006 | 08:34 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
I have both the haynes and chilton 82 - 92 Repair manuals ,
I just did the heads on my car and have a problem with fuel dumping into the crank case , the chilton book reads 40 ft lbs +90 turn and the Haynes states 70 ft lbs , This is an 89 2.8 MPFI . Could someone who has done this before please tell me which is right .
Also since the car has not been run more than just a few minutes and nothing has been taken apart , if the 70ft lbs is the correct one could they just be torqued futher or would it be better to just replace the head gaskets
Old Jun 25, 2006 | 08:39 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
41 ft lbs + 90*, I think, is the same as 70 ft lbs or close to it. one way to check, torque to 41 ft lbs, the reset the wrench for 70 ft lbs and see if it reaches 70 by the time you turn the bolt 90*, i had this dilema, are you using new bolts? and did you put some type of sealer on the threads? And if fuel is getting into the crank case....A. your piston rings are gone. B. you are running very rich or C. your pcv valve is gone Did this happen after you did the heads? Wrong torqeing of the head bolts wouldnt cause fuel to get into your oil
Old Jun 25, 2006 | 08:43 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Used the original bolts , was told they would be ok
did use sealer on them
did'nt have the problem with the fuel in the crack case before the work was done , thats why I think it's a gasket problem
Old Jun 25, 2006 | 08:44 PM
Car: 1986 Firebird
what did you torque to?
Old Jun 25, 2006 | 08:52 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
40ft lbs + 90 turn
Old Jun 25, 2006 | 08:56 PM
Car: 1986 Firebird
can you contact me on aol instant messenger?, talking this was is a pita
Old Jun 25, 2006 | 08:59 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
sorry don't have aol instant messenger
Old Jun 25, 2006 | 09:03 PM
Car: 1986 Firebird
how do you know youre getting fuel in your crank case?
Old Jun 25, 2006 | 09:09 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Checked the oil and it smelled like gas , and was really thin like water , I drained the oil pan and there was twice as much as what was put in , I know water would make the oil creamy and milky brown , This was Black
I know head gaskets keep the water out of the cylinders , and keep the exhaust from escaping into the motor but if they were not torqued right could it push fuel from the cylinder into the block
Old Jun 26, 2006 | 07:22 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
just out of curiosity, what "sealer" did you use on the headbolts? i have never heard of using that on any head bolts when ive done headgaskets before.
Old Jun 26, 2006 | 03:34 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
ARP thread sealer
Old Jun 26, 2006 | 09:58 PM
drdave88's Avatar
Engine: 6.0L
hmmmm. never heard of using thread sealer on head bolts. those may be fun getting back out later on. did someone recommend using this on headbolts to you? just curious since ive never heard of it.
Old Jun 26, 2006 | 10:04 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
for the 2.8 it calls for using the sealer , when the engine is assembled at the factory they use sealer , not all engines call for it but I know the 2.8 does
Haynes 82-92 camaro Pg 2B-8
Chiltons 82-92 camaro Pg 3-23
Old Jun 27, 2006 | 12:39 AM
daves12secV6's Avatar
the only way i could see u getting that much fuel in the oil,is if u have a injector that is stuck wide open
Old Jun 27, 2006 | 11:21 AM
mvftw's Avatar
He's using a thread sealer, NOT a thread locker (like Permatex Red or Blue). This has Teflon, to stop the water from coming up. The head bolts go into the water jackets. Plus this has been beatin' down before but here goes... 60* motors use torque-to-yield bolts (stretch bolts). That is why you go 90* more, that stretches the bolt. They should be replaced, of course you can re-use them, but the torque value can NOT be the same...
Old Jun 28, 2006 | 07:24 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Exactly true. Tightening the head bolts will not keep you from getting fuel into the crankcase...period. Have you been cranking it without it starting? That'll cause it too. Get yourself a pressure guage and check for a drop after the system has been primed.
Old Jul 9, 2006 | 11:25 PM
warezbot's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
My problem turned out to be a bad intake gasket , had a mechanic from where I work come by and look at it. He said with the amount of fuel getting into the crankcase it was'nt injectors .So tore it back down and sure enough was the gasket. Got it all back together now and runs better than it ever has .
Old Jul 10, 2006 | 12:02 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Congrats
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
