Imediate help neeeded!!
Old Jun 26, 2006 | 03:40 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Alright heres the deal.. when rebuilding my engine I forgot to mark the dizzy.. that and I also rotated the crank.. so now I have no clue what cylinder is about to fire or anything.. Is there anyway to check or an easy way to time it with out checking each gear tooth or tearin the engine back apart??? Thanks
Old Jun 26, 2006 | 03:49 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The most reliable way is going to be to pull the valve cover for #1 and rotate the engine until both valves are closed, then make sure the balancer lines up at 0*, then stab away. It doesn't matter which terminal you make #1 on the cap, but the normal one is the front most on the driver side of the cap.
Just make sure that when you stab it, the rotor points to a termianl, and that's your #1 cylinder.
Old Jun 26, 2006 | 03:50 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Block the #1 spark plug hole with a shop rag or paper towel, then rotate the engine by hand till the rag is forced out by the compression, now drop in the dizzy with the rotor pointing at the #1 tower. That should get you close enough to start it and set the timing.
Old Jun 26, 2006 | 03:52 PM
John Im gonna try your idea cause it sounds easier.. Mostly cause I dont have the time to take off the intake plenums to get to the valve covers.. Thanks for both responces tho.. Ill let you know how it goes
RedLeader289
May 28, 2019 01:47 PM
HPE
Apr 30, 2007 12:30 PM
nelapse
Dec 16, 2006 07:33 PM
redlsone
Oct 23, 2006 11:27 AM
Camaro_hunter_d
Apr 1, 2001 02:10 PM
