WOOT, whats missing?
Old Jul 1, 2006 | 03:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Anything missing?
Old Jul 1, 2006 | 04:06 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ac compressor
Old Jul 1, 2006 | 09:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
a v8?
wow i wanna kick myself for even saying that, lol
Old Jul 1, 2006 | 10:02 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
http://blackboard.vcu.edu/bbcswebdav...Engine%201.JPG
Basically go here and take a look at all of my 89' v6 2.8L stuff:
/users/bakersn/89 Camaro/Under Hood
That is under the hood.
btw, what is that bent tube doing there? (pic attached)
Also if you see *this pic* ... there is a circular deal that is there... it is missing on yours.
I hope this helps you some... BTW I have MPFI 2.8L v6... so no carb. I also have A/C.
Old Jul 1, 2006 | 10:40 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
that looks to me to be a PS feed line.
Old Jul 2, 2006 | 12:37 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The bent tubing up there is the fuel feed and return lines.
Old Jul 2, 2006 | 12:44 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
o.O is it supposed to be like that? mine are regular lookin... that looks like when I take my water hose and squeeze the tube to make it stop flowin
Old Jul 2, 2006 | 01:41 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
your ability to stay cool in the summer? woohoo, sign me up for that upgrade
Old Jul 2, 2006 | 07:28 AM
Dale's Avatar
Engine: 350 S-TPI
dave, I'll never put a v8 in this car. In fact, I'm thinking next year of selling it.
scottie, I know whats missing, I took it out. This is more a "look at what I did" post. Fuel lines are stock fuel lines, nothing has been done to them.
dr1, are you wanting to do this? I'll tell you what all the parts are if you want.
Old Jul 2, 2006 | 11:24 AM
Car: IROC Z
Engine: 5.7
do you have a v8 radiator on that? looks to me like the hose is on the v8 side not the v6 side
the battery relocated?
Last edited by 85berlinetta2.8; Jul 2, 2006 at 11:25 AM. Reason: Automerged Doublepost
Old Jul 2, 2006 | 01:05 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Ahh Then, neato!
Old Jul 2, 2006 | 01:24 PM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
I can't tell you how much I would love to do that. I eliminated everything on my daily driver(my 89 chev worktruck) but the wife has to have air conditioning in hers. Every little bit counts on these little motors. Are you reving quicker now Jay?
Here's a pic of my truck with an electric waterpump and a March pulley setup- I'd love to get the V6 this clean. This is all smog legal except for the aircleaner. So easy to work on.
Old Jul 2, 2006 | 07:43 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
wow. dude, you should switch to the 86 style belts. i ahve a "serp" belt from my crank to my alternator (elimintaed AIR) and a "v" belt from my crank to my powersteering pump and water pump. looks MUCH cleaner then the 4 delete pullys you are rocking. belts are cheaper too. unless you got a good reason to stay serp i would eliminate all that crap.
just my .20
PS, i'll take a current engine bay shot later and post it. my bay is looking cleeeeaaan
Old Jul 2, 2006 | 08:20 PM
DRR's Avatar
DRR
just my .20
Jay has 4 delete pulleys? you must be seeing something noone else does because what I see is a complete removal of his smog pump and bypass directly off the crank to the alt. Then he has deleted the A/C in place for a very tinyplastic delete pulley so he can get clearance using the tensioner still and not hit the WP pulley on the top passover. He still has the factory powersteering pulley (which he needs), then back around the WP and then down to the smaller crank pulley
Equals 1 complete removal, 1 delete pulley, and one power pulley-
he doesn't even have 3 delete pullies, he has one.
wheres the clutter, I don't see it. Good job Jay.
Old Jul 2, 2006 | 08:50 PM
Xophertony's Avatar
Axle/Gears: n/a
your right, that is the tensioner (sp?). well, if ya switch out to early style accessorys you would not need one of those either.... but i am a huge fan of empty engine bays....
overall it looks fantastic btw. i am just nit picking.
EDIT* got that picture.
Old Jul 2, 2006 | 09:22 PM
Dale's Avatar
Engine: 350 S-TPI
I'd rather not have the v-belts, plus that would require buying all new accessorys, which the alt is brand new. the ps pump I do need a new one, but its been "Bad" since I had the car, so no I'm gonna rock it.
DRR is exact down to the t on what has been done. Very good eyes.
I still have the v6 radiator, yet I have put the v8 fan system on mine. Battery is in factory position. They switched sides between the 2.8 and 3.1 from what I have noticed.
I have only drove it around the neighborhood to verify that "its ok". Tommorow on the way to work will be the true test. From my small drive, it revs no different. I did this more for clutter control, and for this board so we can have a cheap ac delete setup. A little bit for the weight savings. However, the pump is the heaviest part I took off. All the other shizzle doesnt even weight CLOSE to the pump alone.
Here is what you see....
The pully is the SC idle pully from a 99 L67 (3.8 s/c) engine. The bolt is the correct threads, but not long enough. So I had to get a new bolt. The bolt I found was shouldered, so I had to slowly file the center out a little plasic alighnment thing (you will see when you have used pully in hand, new pully will not have this).
I then had to space it out with 4 washers, and a shock retainer cup(them things that hold the shock rubber in?).
Bolt was long enough, I put a nut on the back side.
I then got an 83.5inch 5 rib belt. It is VERY tight. Now, this worked perfect for my setup, which is smog delete, and underdrive. The next belt down was 82? and the next belt up was 85?. However, I use to have the alt titled out to make up slack on an old belt. So if you have to go to another size, that is an option. I just lucked out on my length.
Old Jul 2, 2006 | 09:44 PM
Xophertony's Avatar
Axle/Gears: n/a
right on man. yeah... that would be alot of money to spend just to avoid a delete pully. a guy in my carclub (cascadecrew) did that just to get rid of the hassles asociated with serp and headers (305 v8). of course there is always somone in the crew parting a car, so the parts were easy to come by... getting them new woul.d be insane!
yeah, thoise compressors are like, 30+ LBS or so right? i never weighed the one off of my GTA (should have)....
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
