sixshooter,doward
Old Jul 3, 2006 | 07:06 AM
daves12secV6's Avatar
sixshooter,doward
hey man when u guys went turbo did u guys change the plugs u guys run?go hoter or colder range etc.im still using the stock replacement delco plugs in mine ,
Old Jul 3, 2006 | 09:17 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yeah I used 2 heat ranges colder. Mine is a little different being the Aluminium head, I used the R24LTS. I think the iron head plugs would be different.
Old Jul 3, 2006 | 02:52 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My camaro isnt boosted, but my grandprix is. When I swapped from the orginal pully (think it was a 3.8" pully) to a 3.4 pully. I had to drop 1 heat range. I think I also changed the gap a little bit too?
I belive the stock boost was 7lbs, 3.4 nets me just shy of 10 (like 9.25-9.5).
Old Jul 5, 2006 | 06:08 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I'm dropping 1 heat range when I swap over to the 3.4... 2.8 loads up on oil too fast to think about going colder.
eric17422001
Classified Ads Feedback Board
Jun 7, 2008 09:22 PM
daves12secV6
May 2, 2006 10:24 PM
Doward
May 16, 2005 09:07 PM
duranged
Mar 28, 2005 09:25 AM
kevo2k6
Nov 23, 2004 01:27 PM
