Acting up again
Old Jul 25, 2006 | 01:43 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Acting up again
I am using my camaro as a daily driver my girlfriends car was totaled and she is haveing problems finding a new car in her price range so she is useing my lancer.
My camaro is idleing low below 750 rpm then it will go upto 1000 then down to 500 and back up the whole time i am at idle. I cleaned out my TB and IAC passages. I also reset the computer and that did not help. Do you think the screw in the TB is backing out?
Old Jul 25, 2006 | 03:51 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
could be anything. check for vacuum leaks, check the voltage on the tps (.55v i believe is the best)... usually a vacuum leak though.
anyone else?
Old Jul 25, 2006 | 04:26 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
My friends car used to do that. It was a vacuum leak. You should be able to hear it.
Old Jul 25, 2006 | 04:59 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
yea i would test the tps as well,,,,could be somthig as simple as a cracked hose,,,,also just a thought but yer a/c is not on at same time is it?
Old Jul 25, 2006 | 10:17 AM
FAST RS's Avatar
Does it with both the AC on and off more so when it is off. I think it may be a vac leak but i dont know where since I can not hear it hissing anywhere. I will also check my TPS this weekend.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
