Code 13, O2 sensor
Old Jul 25, 2006 | 05:02 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Code 13, O2 sensor
What is the deal, I can not keep an o2 sensor in this car since I put the headers on. I had the same problem with my old s10 with headers.
Is this a known problem with headers, or do I need to put a heated one in?
What is the deal!?!?!
Old Jul 25, 2006 | 05:11 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Code 13 means that there is either a short or open in the circuit, our cars don't check the quality of the signal to the ECM, just if the circuit is short or open, I would check continuity between the computer and the O2 harness connector and wiglle all the wiring while you have the guage hooked up.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
dusterbd
Sep 29, 2015 08:40 AM
Logan Bryant
Sep 23, 2015 06:51 AM
