blinking air bag light??
Old Jul 26, 2006 | 04:15 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ive been wanting to post this for a while! The other day i went to do a code read out from the aldl,. and i bypassed the wrong connectors and noticed the air bag light was blinking in some sequence,,, What i want to know is why? and what diognoses is can give me?
Thanks in advance
Oh yea this is on my 91 3.1 r/s
Old Jul 26, 2006 | 04:24 PM
j dezzy's Avatar
Car: 87 TA
if your airbag light is blinking it means that there is a probblem with the airbag. happened with my 91 when I removed the airbag wheel and put on an early model wheel. I just plucked the light out. but if you're looking to keep the wheel. check to make sure it's hooked up and that the fuse is not blown...things like that.
Old Jul 26, 2006 | 06:05 PM
gottfuel's Avatar
im thinking you misunderstood me a lil bit
it does not blink for no reason i was by passing my aldl and i jumped a diff circute looking for the ses terminal when i discoverd the air bag terminal,.,.and what im saying is, when i jumped the circuit, the air bag light began to flash as if it was indicating somthing ,.,.just like the ses light blinks,.,.so what is it telling me via blinks.,,.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Omega
Aug 10, 2015 12:46 PM
