maf to sd swap
Old Jul 26, 2006 | 05:36 PM
daves12secV6's Avatar
maf to sd swap
just wanted to be sure of a few things before i dive into this swap.
my donor car is a 91 camaro 3.1/auto.
if i just remove the harness/sensors/ecm from the donor car.will this stuff swap directly into my 89
do i need to grab the dash harness?
im picking up the engine/trans harness and ecm this weekend.have access to the entire car so if u know of anything else needed for the swap let me know plz
Old Jul 26, 2006 | 06:38 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
What are the benefits from going from MAF to SD??
Old Jul 26, 2006 | 06:44 PM
the sd is much better for the turbo setup the stock maf maxes @ around 7psi,with the sd setup it goes 14.7 psi stock,and can be upgraded further
Old Jul 26, 2006 | 07:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I was just going to say make sure you have means to tune it because SD performs like crap with stock tables on aftermarket parts....
Then I realized it was you posting.
trevor1010
Aug 26, 2015 02:41 PM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
trevor1010
Aug 24, 2015 08:34 PM
Bert87
Aug 23, 2015 03:50 PM
