replacing gasket under intake
Old Jul 30, 2006 | 06:35 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok so im going to be replacing the gasket under my 91 3.1 intake,because it is leaking out the rear.,,.im positive on this so its not the distridutor o ring.,.,
any way i was wonder is there any thing i should/could do once its off?.,,.replace other parts internal/external,. i know ill need to get more plenum gaskets as well.,.,,.but i figure im in there so i might as well replace what i can,.., any advice or info would be great full,..,.,,.any one here have a blueprint type diagram showing where all the bolts are to the intake or a step by step!!?
Thanks in advance
Cheyenne J
Old Jul 30, 2006 | 08:19 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if you pull the intake, just get the intake manifold gasket set. itll have all the plenum and mainfold gaskets, valve cover gaskets, throttle body, EGR, blah blah. but youre gonna have to pull the dist out anyway to get the manifold out so you might as well do the o-ring while its out.
pick up a haynes manual, that way you know torque specs and proper tightening sequence for the intake.
Old Jul 30, 2006 | 08:23 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The only thing you could change would be the pushrods. There is no point tho unless one is bent. When you buy intake gaskets they will come with the 2 intake to head gaskets and the front and back intake to block gaskets. Dont bother with the front and back gaskets. They are known for leaking, just run a thick bead of RTV between the block and intake.
Old Jul 30, 2006 | 02:21 PM
drdave88's Avatar
Engine: 6.0L
you could also put in some roller rockers, or roller tip if you want cheaper. the comp cam 1.52 roller tip rockers will go right on w/o modifications.
Old Jul 30, 2006 | 08:26 PM
gottfuel's Avatar
would roller rocker's and roller tips make any differance in performance or sound?
Old Jul 31, 2006 | 07:10 AM
drdave88's Avatar
Engine: 6.0L
theyll make a small difference in that they reduce friction and open the valves more. for the $, the roller tips are worth it i think. if you get fiero valve covers, you can get 1.6 ratios, but they wont work w/ our stock valve covers.
Old Jul 31, 2006 | 12:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
As dave said, get the haynes manual, it gives tq specs and sequence.
Mark the dizzy WELL!! before you pull it. Then you will need a timing light to set the timing once its back together.
Nothing really worth replacing while its apart. Just inspect inside for metal shavings or oil-sludge build up.
Necro suggested not to use the front n rear blocks, yet it appears he has a 305. So, or intake does NOT use said front n rear blocks, from the factory they just run a bead of black gasket maker, which comes in the set.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
MY87LT
Aug 17, 2015 08:43 AM
mdtoren
Aug 16, 2015 05:45 PM
