Here's what I found out about my dizzy....
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I decided after work to look at a few things. First, I tried to see if the timing chain was off a little. I took an 18mm socket and turned the crank while looking at the rotor. I think it turned maybe 1/2 inch or maybe less when I saw the rotor move so the chain is probably still good. Second, I looked under the dizzy cap and noticed the gouging which occured in the last cap I took off also happened in this one as well (see pic in my last post). Third, the rotor moved slightly left-to-right play about an 1/8 of an inch. I also noticed the rotor would come upward as I pulled on it and I could feel the worm gears hit each other as I rotated the rotor. Bad dizzy? Any thoughts? I moved the dizzy body to see if it was loose or had play...none.
Ken
Ken
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Yeah, that's a crap distributor. Time to visit the parts store for a new one.
There's a bushing in the top of it that keeps everything in line and after the years, that goes bad and gives you what you're describing.
Have fun.
Have fun.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
