Gasket question
Old Sep 20, 2006 | 03:59 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Gasket question
Ok guys, I just need an engine hoist and the 3.4 should be coming home. But I have a question about the gaskets. I went to redline and asked for the 2.8 gasket rebuild set. They said they have I believe it was, FELPRO for I think a hundred dolalrs or so.
What are your thoughts on this brand? Good gaskets? Or should I look for something better? Thank you!
Old Sep 20, 2006 | 04:21 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
not sure there really is a better brand than felpro for aftermarket rebuild sets.
Old Sep 20, 2006 | 04:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
so it's pretty much the best I can get then? haha that's just what I wanted to hear! Thanks!
BTW, in regards to the intake manifold, I know you use the gaskets where the manifold seats on the head, but you use some kind of a sealant on the front and back instead of the provided gaskets right?
Old Sep 20, 2006 | 04:59 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It's just a bead of RTV Silicone.
Old Sep 20, 2006 | 07:00 PM
Engine: 5.7 / 7.4
the kit I got, caint remember if 2.8 or 3.4, cam ew/the rtv instead of little noodle gaskets for the intake ends
Old Sep 21, 2006 | 06:10 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
well you could always us some jb weld to seal the intake ends.....
garenteed not to leak or come back off
Old Sep 21, 2006 | 12:14 PM
Engine: 5.7 / 7.4
w
t
f
Old Sep 21, 2006 | 01:44 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks for the info guys. really good stuff so keep any tips coming!....not to sure if I'll be using JB weld though lol
Old Sep 21, 2006 | 03:40 PM
Car: 91 RS
Engine: 5.0 tbi
don't worry it was a joke.....
Old Sep 21, 2006 | 06:32 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
not discouraging u or anything,
as far as i know FELPRO is the best aftermarket gasket maker.
BUT there's one thread that I read here
on this forum, about felpro head gasket started
leaking in short amount of time..
Im not sure of if it was a mal installation or the product, but
I "PERSONALLY" would go with factory when it comes to a very critical seal
that has to be very precise fitted, ie headgasket..
just wanted to bring it up..
Old Sep 21, 2006 | 07:33 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
When I did the heads on my car, I used the FelPro top end kit and now have well over 100K miles on it since. No problems yet.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
