redline question
Old Oct 7, 2006 | 10:47 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
redline question
Okay...I went out today and bought a Sunpro mini tach, so that I have something to show me if I am about to over-rev another engine again(doing a swap right now thanks to spun bearing). I have no idea where to set the little red-line needle, however. What did the MPFI 2.8s redline at?
Old Oct 7, 2006 | 11:28 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
like 4300 or something? i dunno not to high
Old Oct 8, 2006 | 12:58 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
mine say's 6k rpm redline on my 3.1
Old Oct 8, 2006 | 01:48 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
5500 sounds good
Old Oct 8, 2006 | 10:22 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
my redline starts at 5500, but i have taken her to/over 7000 a few times in neutral with no problems at all. i can take her up to 6500 in first gear (auto in first) and pop it into 2nd via the shifter and the engine doesn't even care, nor the trans... but everything varies in our engines.
Old Oct 9, 2006 | 05:16 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
5500 is factory on mine. although it may actually be different on the carbed since they did have weaker bottom ends.
Old Oct 9, 2006 | 05:48 AM
zoddri's Avatar
Car: Camaro -88
Engine: 2,8 V6
Axle/Gears: yep, got that as well
On my car the orange field starts at 5500 and then it turns red at 6500rpm.
Never tried to rew it that high tough, guess it won't move faster anyway..
Old Oct 9, 2006 | 05:29 PM
ok ok my bad, im thinking of the pos i drive now.
Old Oct 9, 2006 | 08:29 PM
Car: 1984 Camaro
MPFI redline is what I needed....putting an '88 MPFI bottom end + heads in the car, using my intake and carb. I just wanted to make sure that I don't give myself the opportunity to spin another bearing.....
thanks guys!
Old Oct 10, 2006 | 12:04 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
6000 on my 3.1
Old Oct 10, 2006 | 06:45 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
well you could set the redline at stock, but I remember people saying that the stock engine doesn't make anymore power past 4500 so reving past that by a lot wouldn't make any point except trying to wear it out faster. The bottom end of the engine is rated to 7000 but the stock valvetrain wouldn't be very stable at that speed (I wouldn't rev mine past 5500, maybe 6000). If you're not making any power and its not like it sounds good or anything, then why do it?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
