Shakey overdrive in 92 RS
Old Oct 15, 2006 | 10:28 AM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
My girlfriend has a purple V6 RS and she let me drive it the other day. When we went on the highway, i released WOT and it shifted into overdrive. What I noticed is that when it shifts down the car starts shaking and the faster you go the more it shakes. at 50 mph its a little ok, but 60 is kinda bad.
Also about the tranny, when I shift it from neutral to drive, it makes a clunking noise from under the car sometimes. Is that a U-joint?
Old Oct 16, 2006 | 10:14 AM
Sickcuban's Avatar
Car: 1984 Camaro
Axle/Gears: 4.10
Anyone know what could be wrong with it or not?
Old Oct 16, 2006 | 11:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
clunking noise is usualy the u-joints. also inspect the mount.
Check alignment, strut mounts for wear, lower control arm bushings. Haven't realy had to deal w/drive shaft being out of balance, so couldn't tell you the symptoms......
Old Oct 16, 2006 | 11:42 AM
BlownUp Blue's Avatar
Sounds like the torque converter in the transmission. The clunk itself sounds like a u-joint, like someone already suggested. Might want to make sure the tires are correctly balanced.
Old Oct 16, 2006 | 06:50 PM
Sickcuban's Avatar
Car: 1984 Camaro
Axle/Gears: 4.10
yea thats true...I told her to get new tires. it looks like all 4 of her tires are different in size but yea it shakes pretty badly ever since we got it from some other chick who did no maintainance to it. it has like 137,xxx i believe so maybe i should just look at the entire tranny. Thanks guys.
Old Oct 16, 2006 | 09:15 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I bet u ur tranny mount is shot,
even if thats not causing ur symptoms.. they're cheap and easy and
will make a difference in ur ride..
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
