Serpentine Belt
Old Nov 2, 2006 | 09:29 AM
leathalirocz's Avatar
Car: 1988 Irocz
Engine: 355 Stealthram
Transmission: 5speed
Axle/Gears: Stock 10bolt 3.73 posi
Serpentine Belt
Hello, hope someone can help me with this one. I have a 1989 camaro with the 2.8 V6, the ac compressor is going out making all kinds of noise, it doesnt work anyhow so iam looking to remove all of it. Does anyone know what belt to use with the ac removed, and how to run the belt on the pulleys? Thanks in advance Chad
Old Nov 3, 2006 | 07:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
there was a post about this before, i believe since yours has a/c, you have to get the delete pulley or the belt will rub against itself in another spot. do a search it should still be available from GM.
Old Nov 3, 2006 | 10:03 AM
sixgun's Avatar
Car: '86 TPI T/A, 90 Firebird 3.1L
Engine: 3.1, 5.0 TPI
belts and compressors
When the car is bulit w/o A/C the assessories are mounted
totally different.
Normally the A/C compressor should free-wheel if it's not
engaged. The parasitic drag and HP drain is very small. But
still if you want everything, the delete pulley is the way.
Are you saying the compressors clutch is engaging?
sixgun
Old Nov 3, 2006 | 02:35 PM
Car: 1988 Irocz
Sound like the delete pulley is the way to go just wasnt sure if anyone did it without one. Its not engaging but rattles and makes all kinds of noise. Its getting a 305TPI transplant next summer and didnt want to put anymore money into the 2.8 but, thanks for the input, Chad
Old Nov 8, 2006 | 11:23 AM
SageMoonblade's Avatar
OK this isnt all that hard people..... the belt you need is available from any parts store and there is a second hole in the powerstearing pump that will move the pump so the belts wont rub in the center will post a pic of that hole abit later today......
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
