found a vac leak behind plenum
Old Nov 3, 2006 | 03:02 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
I found a vac leak behinde the plenum is an outlet wich has a hose running left and the there is a T spliter and a lil hose from it runs behind the dizzy, and around towards the right of engine ,. i will more tomorow but that small hose is dry rott broken., and while the car is on i can feel the tube sucking in., my girl says when i put my finger over it it has a small change in rpm!,,
What ide like to know is where does this hose go~ and could it be having ant affect on my hp or fuel milage?? this vac leak is forceing "ide say about a good 2 lbs of psi......
Old Nov 3, 2006 | 07:11 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
any vacuum leak will make affect your mileage and power. its taking in air that is not monitored by the MAF so it doesnt know that its there till the o2 sensor notices it and adjusts for it by adjusting fuel, or timing. just get some windshield washer hose and a lil adaptor, cut the rotted stuff off and splice in the new stuff and youre off.
Old Nov 3, 2006 | 10:07 AM
sixgun's Avatar
Car: '86 TPI T/A, 90 Firebird 3.1L
Engine: 3.1, 5.0 TPI
where does it go?
Hose routings are on the sticker in the engine bay.
Sometimes the shop manual has them as well.
But absent those references, I "think" that one runs
around to the front to the cruise control module.
sixgun
Old Nov 3, 2006 | 10:38 AM
gottfuel's Avatar
sixgun
Well i dont have cruise controll,. unfortunatly i cant make it home today to check out my 3.1 r/s to day , but its realy bothering me lol, any one here have a diagram of the back of the plenum? showing vac hoses, and location? i would really be thankfull for that, ,, other then that, it couldnt be coming from the actual windshield washer container could it??i just dont see it using that much vacum if any at all!
Could this vac hose lead to that ball thingy located under the battery stand,, and if so what affect could it have on my engine??
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
