Overly maxed out oil guage!
Old Nov 3, 2006 | 01:27 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok finnaly got home to check some things out, and while i was listening to it run , at about 2500rpm and nnoticed the rpm gauge was not compleatly stable, it went up and down a lil bit, while trying to hold it steady,,,
Also to my suprise, and i would throttle it, i physicaly watched the oil guage reach beyond the 80 psi mark, it literaly went of the chart, not for long just goes over and comes back,,,even if i rev to 3k rpm and hold it will register far over then back to a decent psi! oh "fyi" it never drops to low, just shoots real high for a micro sec,.,.,. What does this mean??
Old Nov 3, 2006 | 02:34 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
mine did that, turned out to be my oil pressure sender
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Apr 30, 2019 12:14 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
