I just bought a 91 Firebird and most the time it will turn over but every once in a while it wont. If I wait about 15 minutes it ill start to turn over again. Anybody have an idea what the hell could be wrong. Please help
check:
batt terminals
batt voltage
batt cables/connections
charging system
batt terminals
batt voltage
charging system
^^^^ what he said, plus make sure you starter isnt binding up, ive had it happen to me when i replaced my starter with a crappy vato zone one. the starters gear was off about a 1/16 of an inch.
when it wont turn over, is there a clicking noise or anything at all, or is there absolutely no noise. kinda of a dumb question too, but you do have power when it wont start right? all your lights,radio, etc still work?
Quote:
Everything still works the lights and everything will still go on but the engine wont do anything. I just noticed last night that when I try to start it and it wont turn over that a yellow light flashes and says security. I dont know what that would be, the guy I bought it off of says theres no alarm system so I dont know what the hell is the matter.Originally Posted by drdave88
when it wont turn over, is there a clicking noise or anything at all, or is there absolutely no noise. kinda of a dumb question too, but you do have power when it wont start right? all your lights,radio, etc still work? Supreme Member
What year is it? My 91 has the VATS system and would do kinda the same thing. It would light everything up but not start. The "chip" in the key was worn down. Bought a new key, hasent done it since. If it dosent turn over and the security light blinks, I would lean to the key being worn.
I had the same problem on my '92 bird - I bypassed the VATS and haven't had the problem since. It could be a worn key too - if you have a spare try using that key and see if the problem goes away.
BTW - the security light is a definite indication of a VATS problem.
