vaccume leak??
Old Nov 21, 2006 | 02:45 PM
TYC-FlipSiCan's Avatar
vaccume leak??
ok this just happened a couple days ago my car use to go fast now its really slow and i have no reason y its going soo slow but not only that it also sounds like i have a turbo it sounds good to but im sooo slow can you guys help me out im thinking of what to do but im lost thx.
Old Nov 21, 2006 | 03:14 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
its your cat plain and simple checker sells a new bolt in cat for like 100 bucks easy fix or u can pull it off and hollow it out
Old Nov 22, 2006 | 11:06 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Nothing else ever goes wrong to make this happen, huh?
It's not that simple. I'm not saying it isn't the cat, but there are a lot of other things to check before you just say that's definitly what it is.
We need more info. How does the car idle, Rough or smooth? Are the manifolds glowing in the dark? Is it all the time that you have this lack of power or just when it's hot/cold? Have you done anything to it recently? Tune-up, washed the engine, anything like that???
Here's how to tell if it's a cat problem: hook up a vacuum guage to the manifold tee on the back of the plennum. Use the small one on the passenger side. Just pull the hoses that are there off and let them hang, nothing major being d/c. Now hook up the vacuum guage.
You should see about 16-18" of vacuum at idle. Hold the throttle up to about 2000 RPM and the vacuum should go up to about 20-22". Now snap the throttle all the way open and let it slam back closed.
You should have seen the vacuum guage go all the way to 0 when you snapped it open, then when it closed, it should have spiked all the way up to about 28 or so. It should spike really high. If it doesn't, then you have an exhaust backpressure problem. Then suspect the CAT.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
