87 firebird 2.8 injection puzzler
Old Nov 22, 2006 | 01:02 PM
Duckman028's Avatar
I am working on my 2.8 engine and I am having a serious injection problem and hopefully someone has crossed this bridge before. I put in new: wire, plugs, 6 injectors, oxy sensor, cap, fuel filter and after all this, still would not run. Soooooooo I decided to lift out the fuel rail to make sure all the new injector were operating and that is when I noticed that only the left side of the fuel rail (all 3 injectors) was spraying. I looked for fuses and found nothing wrong so I switched all the injectors from left to right to make sure the injectors were good and I cranked the engine and once again the left side of the fuel rail sprayed but not the right. So for some reason I am not getting signal for the right side injectors. I also replaced the ECU. If this makes any sense PLEASE shine some light on the on this problem...... It will soon head to the scrap yard... Thank you, Duckman028
Old Nov 22, 2006 | 01:44 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Double check the fuses - the right side and left side have separate fuses. If both injector fuses are good it's probably a wiring problem.
Old Nov 22, 2006 | 02:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
when you replaced the ecu, did you keep your existing prom, or it came with a new prom?
I would recheck the fuses as stated above.
If not that, then I would start tracing wires between them. Starting with the small injector harness on the rail.
Old Nov 22, 2006 | 04:06 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
All the injectors on one bank share both a power circuit, which is always hot with 12v with the key on, and a switched ground which is controlled by the ECM.
Check to make usre you are getting 12v to the injector harness connection, then check the wires at the ECM, like everyone said.
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
E Rod
Aug 28, 2015 05:17 AM
