question about smog
Old Dec 18, 2006 | 01:24 AM
camaro1fan's Avatar
Car: 1990 RS
question about smog
I have a 3.1 v6 camaro. need to smog it again. san diego cali. need to know if not having the heater hose's on the car, and having the fan wired on all the time, (getting it fixed). not make it pass?
Old Dec 18, 2006 | 10:11 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Technically, having the fan wired hard wired to run all the time is a failure. Since the ECM controlls the fans to keep the temp right around 220* for smog reasons, it's a failure in electronic controls, BUT most techs won't even bother to fail it for something like that.
Heater hoses have absolutly nothing to do with smog, so it's fine if they're not there, as long as there's no coolant leak, you should be good.
Old Dec 18, 2006 | 02:20 PM
camaro1fan's Avatar
Car: 1990 RS
ok thank you, that helps me out. would you know happen to know how to test for what is wrong with the fan and how to fix it? thanks for the reply
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 7, 2015 09:55 PM
