DIS HELP!!!!
Old Jan 2, 2007 | 07:46 AM
ap72's Avatar
DIS HELP!!!!
does anyone have pictures of the reluctor ring/crank sensor setup that they use for DIS? I know I have to fashion a trigger with 7 notches, but I don't know where to put the 7th notch in relation to TDC and the sensor.
Old Jan 3, 2007 | 12:57 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
On the 3.4, the sensor is mounted to the timing cover. Then the balancer has kinda a "blade" style setup that triggers the sensor.
I have a cover with the sensor mounted, but the wires are cut. The balancer is on the car and most likely unable to get a picture of it.
Old Jan 3, 2007 | 01:03 PM
daves12secV6's Avatar
pm six_shooter he has fabed up a crank trigger for his own motor,so he should be able to help u out
Old Jan 3, 2007 | 06:32 PM
ap72's Avatar
can that timing cover fit onto a RWD 2.8L?
Old Jan 4, 2007 | 11:37 AM
Dale's Avatar
Engine: 350 S-TPI
yes, it came off a RWD 3.4. The block design is the same.
:edit: aslong as the 2.8 is a serpintine setup, it will work. I dont think it will work on a v-belt setup.
Vintageracer
Jan 10, 2020 05:33 PM
1992Vortec
Aug 31, 2015 08:05 PM
vortech305
Sep 20, 2001 07:47 PM
vortech305
Aug 19, 2001 01:33 PM
vortech305
Aug 14, 2001 03:48 PM
