Harmonic balancer
Old Jan 5, 2007 | 11:26 AM
monk324's Avatar
Harmonic balancer
My son has an 85 firebird 2.8 that is shot now and we are thinking of going with the 3.4 after reading on here, it has a five speed in it would I need to (1 )change the flywheel to a neutrally balanced one (2) use the 2.8 harmonic balancer or get one for the 3.4 (3) do you use the 2.8 injecters or do you have to get 3.4 ones I read in the swap boogie he put 3.4's in but noone else has siad if they did.
thanks forthe help
Old Jan 5, 2007 | 12:39 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
1) Yup, get a neutrally balanced flywheel
2) I would get one for the 3.4 just to be sure
3) 3.4L injectors aren't required to run, but to run well....
Old Jan 5, 2007 | 09:16 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
neutral flywheel/flex
3.4 balancer(your 2.8 one may be balanced with the crank)
3.4 injectors (it can run on 2.8's, but its lean)
Old Jan 6, 2007 | 05:14 PM
monk324's Avatar
thank you for the response
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
