Milling 60v6 heads
Old Jan 12, 2007 | 06:04 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Milling 60v6 heads
If you mill the heads down to increase compression, what would be the best way to make the intake manifold seal? Use 2 intake manifold gaskets per side? RTV a custom phenolic spacer? Not that I'm going to be doing it soon, I've just wondered if and what has been done before.
Old Jan 12, 2007 | 06:47 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I think the consensus is to have the Intake manifold milled to match. Most machine shops can do this
Old Jan 12, 2007 | 11:19 PM
Blue1989RS's Avatar
Car: 1989 RS
would you mill the manifold bottom where it meets the block?
Old Jan 13, 2007 | 06:34 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
yes. if you tried to use a spacer on the sides or something, the ports wouldn't line up properly. how much do you plan to mill the heads?
Old Jan 13, 2007 | 08:50 PM
Blue1989RS's Avatar
Car: 1989 RS
Just enough to bump up the compression a bit but not interfere with the valves. I'd have to do some math and measuring first. Its a 3.1 and when I put it together it seemed like the pistons were really close to the top. It still doesn't seem like it would work by just removing material from the manifold.
Old Jan 14, 2007 | 06:34 AM
firstfirebird's Avatar
It works. If you imagine that the heads and manifold are bolted together and you were to remove the same profile as the top of the block out of the three parts, it would pull the heads and manifold down closer to the crank respectively.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
