new upper intake manifold testing done : available for purchase soon
Old Feb 14, 2007 | 06:49 AM
  #101
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Originally Posted by daves12secV6
there is one thing i forgot to mention about these,they will not work with a 2.8 throttle body due to the way the iac motor hooks up.these must be used with a 3.1 tb
What's the difference and how could us 2.8 guys change over to a 3.1 TB?
Old Mar 9, 2007 | 06:30 PM
  #102
daves12secV6's Avatar
alls u would need is a 3.1 tb,and a new vacum line were it connects from the manifold to the drivers side valve cover.
on a 2.8 the tb has a large line that runs to the back base of the manifold,were it tees to the valve cover as well
on a 3.1 there is no line from the tb to the manifold, just the valvecover to the manifold.
u could pick up the required parts from a junkyard or somone on the boards dirt cheap
anyways flanges are in i got 5 sets
1 set is already used up for firstfirebird so i have enough left to make 4 manifolds.
so if u want one let me know
Old Mar 9, 2007 | 09:47 PM
  #103
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Are you only making 4 more or are there going to be more made as you get in more orders?
Old Mar 9, 2007 | 09:52 PM
  #104
ill be making these 4 for now and if i get more orders later ill will make more
Old Mar 14, 2007 | 11:50 AM
  #105
HPE's Avatar
HPE
Nice work. It looks alot like the one I made about 4 years ago. They work. I have a rare and discontinued FDP 62mm billet TB made specifically for a thirdgen f-body 60*v6 on mine from a guy over in Sweden- factory TB is 52mm. My plenum volume is 4.1 qts- I sit slightly lower than yours by milling out the area where the shraeder valve would hit- thus I have no problem with hood clearance.http://www.cardomain.com/member_page...52_35_full.jpg
Old Mar 14, 2007 | 01:08 PM
  #106
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I like your TB, have you ever had that setup Dyno'd? I'm curious if changing the manifold and TB would help all that much since the heads seem to be the main problem.
Old Mar 14, 2007 | 05:51 PM
  #107
firstfirebird's Avatar
I'm planning on fitting a Northstar 75mm TB on one of these manifolds , Dave is good at helping us out.
EDIT : HPE; I got those flanges made, if you need something PM me and I might be able to help (a good friend of mine has a CNC shop).
Old Mar 14, 2007 | 06:08 PM
  #108
HPE's Avatar
HPE
I have talked about TB size in the past around here. Going to a TB that large will cause a stuble or hesitation in flow because it is just too large for the draw of our engines. It will level out an work fine if opened slow and smooth, but crack that thottle open quickly and it will stumble. 65mm is about as large as I would recommend and even that is pushing it.Note for fact.stock 52mm tb = 308 cfm's62mm tb = 435 cfmsA built TPI V8 motor is running dual 52's and they are twice our displacement.Don't go 75, you will regret it. My opinion of course, but I am just trying to help you not make what I think is an expensive mistake.
Old Mar 14, 2007 | 06:14 PM
  #109
Got the TB for 50 bucks including the IAC and TPS, so it's not an expensive mistake. You think that's too much for a boosted motor?
Actually, if you want to discuss this more, let's do ti in the appropriate place...
https://www.thirdgen.org/forums/dfi-...ork-730-a.html
Old Mar 14, 2007 | 06:39 PM
  #110
boostedv6's Avatar
Firstfirebird, How much would it cost for just a set of flanges for the intake?
Old Mar 14, 2007 | 07:16 PM
  #111
Dave, how do you feel about people buying the flanges that you paid for the programming?
Old Mar 14, 2007 | 08:22 PM
  #112
boostedv6's Avatar
Ok. So Dave, how much would you charge for just a set of flanges?
Old Mar 14, 2007 | 08:53 PM
  #113
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Blue1989RS
I'm curious if changing the manifold and TB would help all that much since the heads seem to be the main problem...
... and Bing-o was his name-o!
Old Mar 14, 2007 | 09:31 PM
  #114
That's where FWD heads come in.
Old Jun 24, 2007 | 04:13 PM
  #115
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Re: new upper intake manifold testing done : available for purchase soon
So, anybody ever install one of these UIMs on stock engine yet, or any NA intake even with minor mods?
What kind of power and mileage changes did you get?
Old Jun 24, 2007 | 07:31 PM
  #116
actually first firebird will get his in a few days,and rob will also have one
Old Jun 25, 2007 | 10:39 AM
  #117
I was going to ask you about that .
Old Jun 25, 2007 | 12:08 PM
  #118
yeah sorry man i got so into working on the camaro now that i got it back it totally sliped my mind
Old Jun 25, 2007 | 02:00 PM
  #119
NP, It's not like I have a running car to put it on (actually it's running, just has a slight knock, lol).
Old Jun 26, 2007 | 11:37 AM
  #120
Blue1989RS's Avatar
Car: 1989 RS
I totally forgot about this project! I'm really interested as well.
Old Nov 4, 2007 | 10:56 PM
  #121
Engine: 3.4
Did I miss it?
Old Nov 5, 2007 | 03:09 PM
  #122
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
if you make a kit for the 2.8 guys ill probabally buy one
Old Nov 5, 2007 | 04:45 PM
  #123
Qoute from Cheech Martin:
Dave's not here, man.
Old Nov 5, 2007 | 05:28 PM
  #124
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
^^^ True, Dave hasn't been on here in a while. He kind of disappeared for other reasons.
Old Mar 21, 2008 | 08:40 PM
  #125
tank12983's Avatar
Car: bandit II Firebird
Engine: 3.1
Transmission: auto
anything going to happen with this?
Old Mar 21, 2008 | 08:44 PM
  #126
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Dave has kind of dropped out of the V6 world. Not sure what went on but I think some problems back home for some reason or another.
Old Mar 21, 2008 | 11:03 PM
  #127
If any of you guys still talk to him, ask where my TB, cam and manifold are. He was supposed to TIG some stuff for me in trade for my cam, but he kept it all.
Old Mar 22, 2008 | 08:45 PM
  #128
^ He's still around, and this is what your stuff went toward, John....
Attached Thumbnails new upper intake manifold testing done : available for purchase soon-1372989248.jpg   new upper intake manifold testing done : available for purchase soon-915358849.jpg   new upper intake manifold testing done : available for purchase soon-4008800519.jpg
Old Mar 22, 2008 | 08:49 PM
  #129
^ A bunch of us are patiently waiting to cross paths with him at the track, but we haven't met up with him yet. Will definitely let you know when we finally do though....
Gaspar
Old Mar 22, 2008 | 09:43 PM
  #130
Where is he posting that?
Old Mar 22, 2008 | 09:56 PM
  #131
^ I sent you a picture of him holding a sign of his new hang out, he's been on Fubar.com. I really wish you luck w/getting your money back from him, all I want is to get him in front of me... for a nice friendly chat lol!
Gaspar
Old Mar 22, 2008 | 09:59 PM
  #132
Fubar.com
UserID: IROC AKA ~~TROUBLE~~
Although my cousin Rob wrote this guy off awhile back, I still feel that the guy owes my cousin a very large sum of money. I really do hope that you get your money back from him John....
Gaspar
Attached Thumbnails new upper intake manifold testing done : available for purchase soon-490589577.jpg
Old Mar 23, 2008 | 12:41 PM
  #133
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
So i take it these intakes were a NO GO??
Old Mar 23, 2008 | 01:01 PM
  #134
^ From what my cousin Rob told me, the intakes were poorly made anyway. He never braced them properly on the inside, as the top center section of the plenum would cave downward whenever he put a load on it, you could even see it happening at idle if you looked carefully....
Gaspar
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mustangman65_79
Aug 8, 2015 12:07 PM
