waterpump /timing cover question
Old Feb 2, 2007 | 04:02 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Ok, this is a weird question but I already did a search and found no real results.
Does anybody like those torx bolts found on some of the 2.8 waterpumps and timing covers? I assume most people don't. I personally prefer the regular bolts found on the 3.1s and the 3.4s and older 2.8s.
So here are my questions.
1. Can I just use the regular waterpump/timing cover bolts from a 3.1 or 3.4 instead of the torx bolts from the 2.8 to bolt down the timing cover and waterpump? (swapping in a 3.4)
2. If so, what about the torque specs? Would it be the same as the torx bolts or would it be diferent?
3. Also, anyone recommend a certain brand of sealer to use on the bolts to make sure there are no coolant leaks and what not?
Thank you!
Old Feb 2, 2007 | 10:17 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I would think the install would be the same as the torx heads just make sure the hex bolts heads leave enough room for a socket
Old Feb 2, 2007 | 02:18 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yep, you can swap over to hex head bolts. I did that exact thng with my Franken60 build in my Jimmy.
Old Feb 4, 2007 | 10:02 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks guys. Just the answers I was looking for!!!
Old Feb 5, 2007 | 10:19 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I personally like the Torx bolts.
Old Feb 5, 2007 | 05:40 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hmmmm....I have to admit that i love the look of the torx and all....but working on them??? That be a different story! lol
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
