Urgent - How to Pull Fuel Rail and Injectors 3.1L
Old Feb 4, 2007 | 10:27 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I have my 92 Camaro 3.1L down to the Fuel Rail, Injectors, and Lower Intake Plenum (replacing the valve lifters)...
How do you get the Fuel Rail and Injectors out????????? This is a single fuel rail with injectors out each side at an angle so it won't lift straight up without bending the injectors...
If the injectors have to come out one at a time, how do you get them out individually.???
Also, how can I test the injectors and/or clean them before I re-assemble since they are a pain to get to once its back together..???
Old Feb 4, 2007 | 10:37 AM
firstfirebird's Avatar
You shouldn't need to get the injectors out to do the rockers. I did just put new injectors and rockers in so I'll help you if I can.
Once you remove the two bolts holding down the fuel rail, gently rock the fuel rail from left to right as your pulling up. Mine came right out. Once you've got the fuel rail off, flip it over and there is small clips that hold the inj to the rail. The clips have to be turned about 90* (they will only go one way) and the inj should come out with a little twisting/pulling motion.
Old Feb 4, 2007 | 10:46 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I am doing the valve lifters so I have to pull the intake... I don't see a way to pull it without pulling the fuel rail, fuel injectors, lower intake plenum, and then the intake over the lifter valley in that order...
Old Feb 4, 2007 | 10:57 AM
Sorry, you did say lifters, I was thinking rockers. I'll dig out the Haynes and get back if I missed anything.
Old Feb 5, 2007 | 10:27 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Thanks, got them out.. Just didn't want to pull until I was sure that was the right way... But, now I have camshaft problems....
Old Feb 5, 2007 | 03:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I just take the 2 fuel rail bolts out, and then stick a long big screwdriver right down the middle of the rail from the front and pry. The injectors wiggle around in the rail, there just held in with rubber.
Steve78LT
Feb 24, 2016 12:15 AM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
