CODE 33 IDLE @ 2,000 RPM
Old Feb 5, 2007 | 12:55 PM
syko's Avatar
So I replaced a my O2 Sensor and cleared the computer, and finally patched the hole in my muffler so that got rid of my Codes 13 and 34. Now, code 33 has shown up.
When I start my car cold, I have to hold the key in ignition for about 3-4 secs for the car to finally start. It'll crank the whole time, but won't "catch" till about the fourth second. Anyways, once it's warmed up, it'll easily start with a quick turn of the key. However, if I let it cool down (say, leave it parked for about an hour), it'll go back to the 3-4 second start...
Anyone have any tips?
Old Feb 5, 2007 | 05:17 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
with an idle that high the first thing to check for is vacuum leaks, then an IAC problem. I think you should get the odle problem squared away before you start chasing down codes for rich/lean conditions.
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
