Harmonic Balancer - 92 3.1L V6
Old Feb 6, 2007 | 08:48 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
My harmonic balancer appears to have a metal sleeve over it where the oil seal from the timing chain cover rides. The sleeve has what appear to be several wear type grooves (unless they are supposed to be there)... Is this a replaceable sleeve?? If so, how do you get them off and the new ones back on???
Old Feb 6, 2007 | 10:12 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
if its what I'm thinking, it shouldnt be there. It should be pressed into the timing cover.
Old Feb 6, 2007 | 10:30 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I was checking the parts sites and they list a Harmonic Balancer Repair Sleeve but they also list a Timing Cover Repair Sleeve??? It appears to be a press fit to the balancer though...
Old Feb 6, 2007 | 03:07 PM
Dale's Avatar
Engine: 350 S-TPI
I was thinking timing cover sleeve. Any way you can get a picture of it and post?
HoosierinWA
Oct 7, 2015 10:15 AM
monte87cortez
Sep 26, 2015 08:10 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
roysatikas
Sep 22, 2015 08:15 PM
Magman
Sep 13, 2015 12:14 AM
