My oil pressure gauge all of the sudden is showing incredibly high pressure...
Old Feb 7, 2007 | 03:38 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Ok, so about 2 weeks ago or so I noticed my oil pressure gauge was way past the 60 mark (I swapped to a 145 cluster about 4 months ago so it shows 60 instead of 80 as the highest mark). I checked the oil and it was half-way in the safe area so I figured it might just be from the cold weather we started having. It would stop doing it every now and then and act normal but it'd still go back to being way past. It is 70* out today and it's still doing it. I checked the oil with the car running and it was really far up the dipstick and when I got home I checked it again after I turned the car off and it was back down in the safe area (but lower than usual since the oil in the cylinders hadn't settled back down yet). What is causing this? Is it something I need to be worried about?
Old Feb 8, 2007 | 01:17 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
the sender is probably bad.
Old Feb 8, 2007 | 03:22 PM
Car: 2012 Corvette
Engine: LS3
Sounds like that'll be fun to replace. Course all day today the damn thing was showing what it usually shows.
Old Feb 8, 2007 | 03:47 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Ive been told its pretty easy. Unscrew the old one, put in new one. Its right above the oil filter. Ive been meaning to change mine for a while, but I havent gotten around to it.
Attached Thumbnails My oil pressure gauge all of the sudden is showing incredibly high pressure...-101_0097s.jpg
Old Feb 8, 2007 | 05:16 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Super easy...like 5 mintues to do.
Old Feb 8, 2007 | 05:30 PM
Car: 2012 Corvette
Engine: LS3
I see that now, thanks for the picture. I'll go ahead and replace it next oil change. Thanks for the help.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
