How hard to install a TCC?
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I'm gonna drain the tranny fluid and was wondering how how it is to replace the TCC? Any helpful tips or suggesstions?
Ken
Ken
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Lets see - you can't replace the Torque Converter Clutch unless your willing to saw the torque converter in half and then reweld/rebalance it. It requires removing the entire transmission at the very least to get at the torque converter.
I'm assuming since your only changing the fluid you mean the Torque Converter Clutch Solenoid, which is easily replaced when dropping the pan.
With the pan off, you'll see a set of wires (the ONLY wires in the entire transmission), follow those to a small device bolted very near the torque converter at the front of the tranny - you'll need to remove those bolts, pull it out and reinstall.
Dude...my bad. I shoulda said the solenoid in the post. I'll pick one up and try my luck.Thanks!
Ken
Ken
ambainb
Apr 25, 2016 09:21 PM
